Ir para o conteúdo principal
Asus ZenWatch 2 Battery Replacement
O que você precisa
    1. Asus ZenWatch 2 Battery Replacement, Battery: passo 1, imagem 1 %32 Asus ZenWatch 2 Battery Replacement, Battery: passo 1, imagem 2 %32 Asus ZenWatch 2 Battery Replacement, Battery: passo 1, imagem 3 %32
      • Remove the four 3.5mm screws to detach the case using the T5 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Asus ZenWatch 2 Battery Replacement: passo 2, imagem 1 %32 Asus ZenWatch 2 Battery Replacement: passo 2, imagem 2 %32
      • Slide the spudger under the battery and lift to remove.
      Pergunte ao FixBot
      Comentar
Conclusão
16 outras pessoas executaram este guia.
Moriah
Membro desde: 02/20/17
811 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G1, Leahy Spring 2017 Membro de USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 Membros
Autoria de 20 guias
13Comentários do guia
Where do you get the battery?
Mark Miser - Responder Compartilhar
Sir,
I own Zenwatch 2 and it is just 14 months old. I left it uncharged for months. Now it is not at all charging. In Service Centre, they said Asus did not send any replacement spares even to test what was wrong.
I am from Mumbai, India. Where can i purchase replacement Battery so that i can try? Please help me sir.
Vijaykumar S
Mumbai
vijai kumar - Responder Compartilhar
Only one place I know of to find them: http://www.asusparts.eu/Asus-0B200-01630...
Terrance - Responder Compartilhar
Hello I have ZenWatch 2 Battery WI502Q-SL-BD need help looking Replacement Battery
Angel Alfredo Grant - Responder Compartilhar
i used non original battery, link here. Compare here.
4spam - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 55
Ao todo: 18,918
