Ir para o conteúdo principal
Asus ZenFone 5 Touch Sensor Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Asus ZenFone 5 Touch Sensor Replacement, Battery: passo 1, imagem 1 %32
    • Heat up the iOpener in the microwave for 30 seconds.
    • Caution: when the iOpener is heated up, hold it by the sides to prevent bodily harm.
    Pergunte ao FixBot
    Comentar
  2. Asus ZenFone 5 Touch Sensor Replacement: passo 2, imagem 1 %32
    • Place the iOpener on the side of the phone until the iOpener gets cool (approximately 10-15 minutes).
    • Reheat the iOpener and reapply it to the other side of the phone.
    Pergunte ao FixBot
    Comentar
  3. Asus ZenFone 5 Touch Sensor Replacement: passo 3, imagem 1 %32 Asus ZenFone 5 Touch Sensor Replacement: passo 3, imagem 2 %32
    • Gently slide the jimmy along the edges of the phone to break the adhesive.
    • Use opening picks and the opening tool to pry the back cover off.
    • The use of metal tools as shown in the photos is potentially dangerous as the battery is exposed along the edges of the case and risk of puncture is high. Choose an ESD safe tool instead.
    • There are 6 different tabs on each side of the phone that might take force to get apart.
    • Repeat the heating and prying process until the back cover can be fully removed.
    Pergunte ao FixBot
    Comentar
  4. Asus ZenFone 5 Touch Sensor Replacement: passo 4, imagem 1 %32 Asus ZenFone 5 Touch Sensor Replacement: passo 4, imagem 2 %32
    • Use the #00 phillips head to take out the six phillips #00 3.175mm screws on the top cover plate.
    • Use the spudger to release the clasps along the edge of the top plate.
    Pergunte ao FixBot
    Comentar
  5. Asus ZenFone 5 Touch Sensor Replacement: passo 5, imagem 1 %32
    • Disconnect the press fit connector located near the upper right corner of the battery to disengage the battery from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Asus ZenFone 5 Touch Sensor Replacement: passo 6, imagem 1 %32 Asus ZenFone 5 Touch Sensor Replacement: passo 6, imagem 2 %32
    • Use the same screwdriver to remove the five phillips #00 3.96mm screws along the bottom plate.
    • Use the spudger to pry the bottom plate off.
    Pergunte ao FixBot
    Comentar
  7. Asus ZenFone 5 Touch Sensor Replacement: passo 7, imagem 1 %32 Asus ZenFone 5 Touch Sensor Replacement: passo 7, imagem 2 %32
    • Pull on the two black tabs on the bottom of the battery until the battery is released.
    • Gently pull the battery out of its socket.
    Pergunte ao FixBot
    Comentar
  8. Asus ZenFone 5 Touch Sensor Replacement, Touch Sensor: passo 8, imagem 1 %32 Asus ZenFone 5 Touch Sensor Replacement, Touch Sensor: passo 8, imagem 2 %32
    • On the back shell of the phone, push with pressure on the touch sensor until it pops out.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
I might replace the introduction picture in this guide for one that doesn’t have the background missing on the right side.
Alex Watkins - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 560
