Introdução
If your Asus ZenBook UX330U or UX330UA cannot connect to Wi-Fi, then you may need to replace your Wi-Fi adapter. Before using this guide, look at the troubleshooting page located here for possible fixes that do not require any disassembly. This guide can be used to remove the Wi-Fi adapter for the ASUS ZenBook UX330U or UX330UA.
Before beginning any device disassembly, please power off and unplug your device.
O que você precisa
Before starting any device dissasembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin.
Remove the alligator clip at the end of the bracelet by simply pulling it off, to reveal the bullet connector.
Insert the bullet connector into the ground port of an outlet.
