Ir para o conteúdo principal
Asus Z54C-JS31 Display Replacement
O que você precisa
    1. Asus Z54C-JS31 Display Replacement, Battery: passo 1, imagem 1 %32 Asus Z54C-JS31 Display Replacement, Battery: passo 1, imagem 2 %32 Asus Z54C-JS31 Display Replacement, Battery: passo 1, imagem 3 %32
      • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
      • Slide the switch on the top right corner to the right.
      • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Asus Z54C-JS31 Display Replacement, Display: passo 2, imagem 1 %32 Asus Z54C-JS31 Display Replacement, Display: passo 2, imagem 2 %32 Asus Z54C-JS31 Display Replacement, Display: passo 2, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Open up the laptop and locate the two circular stickers at the bottom corners of the display.
      • Use a pair of tweezers to remove the two black stickers covering the screws.
      • Using a Philips #000 screwdriver, remove the two 9mm screws.
      Pergunte ao FixBot
      Comentar
    2. Asus Z54C-JS31 Display Replacement: passo 3, imagem 1 %32 Asus Z54C-JS31 Display Replacement: passo 3, imagem 2 %32
      • Use the plastic opening tool to pop off the plastic border around the display.
      Pergunte ao FixBot
      Comentar
    3. Asus Z54C-JS31 Display Replacement: passo 4, imagem 1 %32 Asus Z54C-JS31 Display Replacement: passo 4, imagem 2 %32 Asus Z54C-JS31 Display Replacement: passo 4, imagem 3 %32
      • Remove the two 9mm screws from the top corners of the display with a Phillips #000 screwdriver.
      • Carefully lift the display out and place the screen face down on the keyboard.
      Pergunte ao FixBot
      Comentar
    4. Asus Z54C-JS31 Display Replacement: passo 5, imagem 1 %32
      • Disconnect the display cable connector attached to the display.
      Pergunte ao FixBot
      Comentar
Conclusão
Mark DeSimone
Membro desde: 10/19/17
801 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Membro de UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 Membros
Autoria de 48 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 454
