Ir para o conteúdo principal
Asus X751L Wireless Card Replacement
O que você precisa
    1. Asus X751L Wireless Card Replacement, Keyboard: passo 1, imagem 1 %32
      • With the screen closed, place your laptop upside-down with the front facing you.
      • Remove the six 14.6mm Phillips #00 screws.
      • Remove the four 6.6mm Phillips #00 screws.
      Pergunte ao FixBot
      Comentar
    2. Asus X751L Wireless Card Replacement: passo 2, imagem 1 %32
      • Flip the laptop over and open the lid.
      • Pry around the edges of the laptop base using the plastic opening tool.
      • Prying too hard can break the plastic clips.
      Pergunte ao FixBot
      Comentar
    3. Asus X751L Wireless Card Replacement: passo 3, imagem 1 %32 Asus X751L Wireless Card Replacement: passo 3, imagem 2 %32 Asus X751L Wireless Card Replacement: passo 3, imagem 3 %32
      • Carefully lift the keyboard up.
      • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
      • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
      Pergunte ao FixBot
      Comentar
    1. Asus X751L Wireless Card Replacement, Wireless Card: passo 4, imagem 1 %32
      • Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Asus X751L Wireless Card Replacement: passo 5, imagem 1 %32
      • Using your fingers, lightly lift up on the black and white antenna cords.
      Pergunte ao FixBot
      Comentar
    3. Asus X751L Wireless Card Replacement: passo 6, imagem 1 %32
      • With your fingers lightly pull the wireless card out of the slot.
      • Make sure to keep the card parallel with the motherboard when removing from the slot.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 17-2, Blackwell Spring 2017 Membro de USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Membros
Autoria de 35 guias
1Comentário do guia
I feel the existing WiFi card is not very good. Is there is better one I can get for the Asus X751L?
July 3, 2023.
cookbake2 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 33
Ao todo: 2,834
