Ir para o conteúdo principal
Asus X751L Battery Replacement
O que você precisa
  1. Asus X751L Battery Replacement, Keyboard: passo 1, imagem 1 %32
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  2. Asus X751L Battery Replacement: passo 2, imagem 1 %32
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
    Pergunte ao FixBot
    Comentar
  3. Asus X751L Battery Replacement: passo 3, imagem 1 %32 Asus X751L Battery Replacement: passo 3, imagem 2 %32 Asus X751L Battery Replacement: passo 3, imagem 3 %32
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
    Pergunte ao FixBot
    Comentar
  4. Asus X751L Battery Replacement, Battery: passo 4, imagem 1 %32
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
    Pergunte ao FixBot
    Comentar
  5. Asus X751L Battery Replacement: passo 5, imagem 1 %32 Asus X751L Battery Replacement: passo 5, imagem 2 %32
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
    Pergunte ao FixBot
    Comentar
  6. Asus X751L Battery Replacement: passo 6, imagem 1 %32 Asus X751L Battery Replacement: passo 6, imagem 2 %32 Asus X751L Battery Replacement: passo 6, imagem 3 %32
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
John Enderton
Membro desde: 02/02/17
612 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 17-2, Blackwell Spring 2017 Membro de USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Membros
Autoria de 5 guias
6Comentários do guia
Very nice, thank you !
anh
barzamjavel - Responder Compartilhar
very nice, thank you !
Anh
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Responder Compartilhar
Your instructions were easy to follow. Thank you!!!
theresa collet - Responder Compartilhar
very helpful
khan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 28
Últimos 30 dias: 69
Ao todo: 14,423
