Ir para o conteúdo principal
Asus X551CA Power Button Replacement
O que você precisa
    1. Asus X551CA Power Button Replacement, Keyboard Plate Cover: passo 1, imagem 1 %32
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      Pergunte ao FixBot
      Comentar
    2. Asus X551CA Power Button Replacement: passo 2, imagem 1 %32
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      Pergunte ao FixBot
      Comentar
    3. Asus X551CA Power Button Replacement: passo 3, imagem 1 %32
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      Pergunte ao FixBot
      Comentar
    4. Asus X551CA Power Button Replacement: passo 4, imagem 1 %32 Asus X551CA Power Button Replacement: passo 4, imagem 2 %32 Asus X551CA Power Button Replacement: passo 4, imagem 3 %32
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      Pergunte ao FixBot
      Comentar
    5. Asus X551CA Power Button Replacement: passo 5, imagem 1 %32
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      Pergunte ao FixBot
      Comentar
    1. Asus X551CA Power Button Replacement, Power Button: passo 6, imagem 1 %32
      • Locate the power button in the corner of the keyboard plate cover.
      • Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
      Pergunte ao FixBot
      Comentar
    2. Asus X551CA Power Button Replacement: passo 7, imagem 1 %32
      • Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Asus X551CA Power Button Replacement: passo 8, imagem 1 %32
      • Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
Josh
Membro desde: 04/10/14
2.970 Reputação
Autoria de 12 guias
Equipe
Cal Poly, Team 7-22, Regan Spring 2014 Membro de Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Membros
Autoria de 70 guias
1Comentário do guia
I broke the middle ribbon! Do you know if that is replaceable? What part number would I order?
crwfd - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 44
Ao todo: 13,381
