Ir para o conteúdo principal
Asus X551CA LCD Replacement
O que você precisa
  1. Asus X551CA LCD Replacement, Keyboard Plate Cover: passo 1, imagem 1 %32
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    Pergunte ao FixBot
    Comentar
  2. Asus X551CA LCD Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    Pergunte ao FixBot
    Comentar
  3. Asus X551CA LCD Replacement: passo 3, imagem 1 %32
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    Pergunte ao FixBot
    Comentar
  4. Asus X551CA LCD Replacement: passo 4, imagem 1 %32 Asus X551CA LCD Replacement: passo 4, imagem 2 %32 Asus X551CA LCD Replacement: passo 4, imagem 3 %32
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Pergunte ao FixBot
    Comentar
  5. Asus X551CA LCD Replacement: passo 5, imagem 1 %32
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Pergunte ao FixBot
    Comentar
  6. Asus X551CA LCD Replacement, Hard Drive: passo 6, imagem 1 %32
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Asus X551CA LCD Replacement: passo 7, imagem 1 %32
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
    Pergunte ao FixBot
    Comentar
  8. Asus X551CA LCD Replacement: passo 8, imagem 1 %32
    • Once it is free, remove the hard drive from its internal cavity.
    Pergunte ao FixBot
    Comentar
  9. Asus X551CA LCD Replacement, Spacer: passo 9, imagem 1 %32
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
    Pergunte ao FixBot
    Comentar
  10. Asus X551CA LCD Replacement: passo 10, imagem 1 %32
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
    Pergunte ao FixBot
    Comentar
  11. Asus X551CA LCD Replacement, WiFi Card: passo 11, imagem 1 %32
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    Pergunte ao FixBot
    Comentar
  12. Asus X551CA LCD Replacement: passo 12, imagem 1 %32
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    Pergunte ao FixBot
    Comentar
  13. Asus X551CA LCD Replacement: passo 13, imagem 1 %32
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    Pergunte ao FixBot
    Comentar
  14. Asus X551CA LCD Replacement, Battery: passo 14, imagem 1 %32
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
    Pergunte ao FixBot
    Comentar
  15. Asus X551CA LCD Replacement, Motherboard: passo 15, imagem 1 %32
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
    Pergunte ao FixBot
    Comentar
  16. Asus X551CA LCD Replacement: passo 16, imagem 1 %32 Asus X551CA LCD Replacement: passo 16, imagem 2 %32
    • Now, locate the two wires connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  17. Asus X551CA LCD Replacement: passo 17, imagem 1 %32 Asus X551CA LCD Replacement: passo 17, imagem 2 %32
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
    Pergunte ao FixBot
    Comentar
  18. Asus X551CA LCD Replacement: passo 18, imagem 1 %32 Asus X551CA LCD Replacement: passo 18, imagem 2 %32
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
    Pergunte ao FixBot
    Comentar
  19. Asus X551CA LCD Replacement: passo 19, imagem 1 %32
    • Remove the motherboard from the case by gently lifting it upward.
    Pergunte ao FixBot
    Comentar
  20. Asus X551CA LCD Replacement, Front Display Bezel: passo 20, imagem 1 %32
    • Locate both of the hinges that connect the monitor to the bottom plate cover.
    Pergunte ao FixBot
    Comentar
  21. Asus X551CA LCD Replacement: passo 21, imagem 1 %32 Asus X551CA LCD Replacement: passo 21, imagem 2 %32
    • Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
    Pergunte ao FixBot
    Comentar
  22. Asus X551CA LCD Replacement: passo 22, imagem 1 %32
    • Once the screws are removed, the monitor should easily lift away from the bottom plate cover
    Pergunte ao FixBot
    Comentar
  23. Asus X551CA LCD Replacement: passo 23, imagem 1 %32
    • Locate the two stickers that cover up the screws that hold the front bezel in place
    Pergunte ao FixBot
    Comentar
  24. Asus X551CA LCD Replacement: passo 24, imagem 1 %32 Asus X551CA LCD Replacement: passo 24, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove these stickers.
    • The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
    Pergunte ao FixBot
    Comentar
  25. Asus X551CA LCD Replacement: passo 25, imagem 1 %32
    • Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
    Pergunte ao FixBot
    Comentar
  26. Asus X551CA LCD Replacement: passo 26, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
    Pergunte ao FixBot
    Comentar
  27. Asus X551CA LCD Replacement: passo 27, imagem 1 %32 Asus X551CA LCD Replacement: passo 27, imagem 2 %32
    • Once the screws are taken out, the front bezel is ready to be removed.
    • Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
    • Gently use hands if necessary to separate the front bezel from the back.
    Pergunte ao FixBot
    Comentar
  28. Asus X551CA LCD Replacement: passo 28, imagem 1 %32
    • Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
    Pergunte ao FixBot
    Comentar
  29. Asus X551CA LCD Replacement, LCD: passo 29, imagem 1 %32
    • Locate the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
    Pergunte ao FixBot
    Comentar
  30. Asus X551CA LCD Replacement: passo 30, imagem 1 %32 Asus X551CA LCD Replacement: passo 30, imagem 2 %32
    • Use the Philips #0 screwdriver to remove the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
    Pergunte ao FixBot
    Comentar
  31. Asus X551CA LCD Replacement: passo 31, imagem 1 %32
    • Once the screws are removed, lift up the LCD to expose the wire connecting the back bezel to the LCD.
    Pergunte ao FixBot
    Comentar
  32. Asus X551CA LCD Replacement: passo 32, imagem 1 %32
    • Gently unhook the wire from the back bezel to allow the LCD to be flipped over.
    Pergunte ao FixBot
    Comentar
  33. Asus X551CA LCD Replacement: passo 33, imagem 1 %32
    • Once flipped over, locate the ribbon that is connected to the back of the LCD.
    Pergunte ao FixBot
    Comentar
  34. Asus X551CA LCD Replacement: passo 34, imagem 1 %32 Asus X551CA LCD Replacement: passo 34, imagem 2 %32
    • Gently tug on the ribbon to remove it from the LCD.
    Pergunte ao FixBot
    Comentar
  35. Asus X551CA LCD Replacement: passo 35, imagem 1 %32
    • Now that the ribbon has been detached from the back, carefully remove the LCD.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Josh
Membro desde: 04/10/14
2.970 Reputação
Autoria de 12 guias
Equipe
Cal Poly, Team 7-22, Regan Spring 2014 Membro de Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Membros
Autoria de 15 guias
1Comentário do guia
You don't need to disassemble the entire unit to get the panel out. Seems an overkill
Res Q Service - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 11,348
