Ir para o conteúdo principal
Asus X551CA Fan Replacement
O que você precisa
  1. Asus X551CA Fan Replacement, Keyboard Plate Cover: passo 1, imagem 1 %32
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    Pergunte ao FixBot
    Comentar
  2. Asus X551CA Fan Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    Pergunte ao FixBot
    Comentar
  3. Asus X551CA Fan Replacement: passo 3, imagem 1 %32
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    Pergunte ao FixBot
    Comentar
  4. Asus X551CA Fan Replacement: passo 4, imagem 1 %32 Asus X551CA Fan Replacement: passo 4, imagem 2 %32 Asus X551CA Fan Replacement: passo 4, imagem 3 %32
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Pergunte ao FixBot
    Comentar
  5. Asus X551CA Fan Replacement: passo 5, imagem 1 %32
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Pergunte ao FixBot
    Comentar
  6. Asus X551CA Fan Replacement, Hard Drive: passo 6, imagem 1 %32
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Asus X551CA Fan Replacement: passo 7, imagem 1 %32
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
    Pergunte ao FixBot
    Comentar
  8. Asus X551CA Fan Replacement: passo 8, imagem 1 %32
    • Once it is free, remove the hard drive from its internal cavity.
    Pergunte ao FixBot
    Comentar
  9. Asus X551CA Fan Replacement, Spacer: passo 9, imagem 1 %32
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
    Pergunte ao FixBot
    Comentar
  10. Asus X551CA Fan Replacement: passo 10, imagem 1 %32
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
    Pergunte ao FixBot
    Comentar
  11. Asus X551CA Fan Replacement, WiFi Card: passo 11, imagem 1 %32
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    Pergunte ao FixBot
    Comentar
  12. Asus X551CA Fan Replacement: passo 12, imagem 1 %32
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    Pergunte ao FixBot
    Comentar
  13. Asus X551CA Fan Replacement: passo 13, imagem 1 %32
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    Pergunte ao FixBot
    Comentar
  14. Asus X551CA Fan Replacement, Battery: passo 14, imagem 1 %32
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
    Pergunte ao FixBot
    Comentar
  15. Asus X551CA Fan Replacement, Motherboard: passo 15, imagem 1 %32
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
    Pergunte ao FixBot
    Comentar
  16. Asus X551CA Fan Replacement: passo 16, imagem 1 %32 Asus X551CA Fan Replacement: passo 16, imagem 2 %32
    • Now, locate the two wires connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  17. Asus X551CA Fan Replacement: passo 17, imagem 1 %32 Asus X551CA Fan Replacement: passo 17, imagem 2 %32
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
    Pergunte ao FixBot
    Comentar
  18. Asus X551CA Fan Replacement: passo 18, imagem 1 %32 Asus X551CA Fan Replacement: passo 18, imagem 2 %32
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
    Pergunte ao FixBot
    Comentar
  19. Asus X551CA Fan Replacement: passo 19, imagem 1 %32
    • Remove the motherboard from the case by gently lifting it upward.
    Pergunte ao FixBot
    Comentar
  20. Asus X551CA Fan Replacement, Fan: passo 20, imagem 1 %32
    • Once the mother board is removed, locate the fan.
    Pergunte ao FixBot
    Comentar
  21. Asus X551CA Fan Replacement: passo 21, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the 5.5 mm Phillips #0 screw holding the fan in place.
    Pergunte ao FixBot
    Comentar
  22. Asus X551CA Fan Replacement: passo 22, imagem 1 %32
    • Lift the fan out of the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Josh
Membro desde: 04/10/14
2.970 Reputação
Autoria de 12 guias
Equipe
Cal Poly, Team 7-22, Regan Spring 2014 Membro de Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Membros
Autoria de 15 guias
1Comentário do guia
Upgrade the memory while you have the motherboard out. 8GB PC3L-12800 SODIMM
iceman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 6,197
