Ir para o conteúdo principal
Asus X200MA Fan Replacement
O que você precisa
    1. Asus X200MA Fan Replacement, Back Panel: passo 1, imagem 1 %32
      • Remove the following six screws:
      • Six 4 mm screws using a Phillips #0 screwdriver.
      • Remove the following one screw:
      • One 14 mm screw using a Phillips #0 screwdriver.
      • The 14mm screw goes in the center.
      Pergunte ao FixBot
      Comentar
    2. Asus X200MA Fan Replacement: passo 2, imagem 1 %32
      • Take two rubber caps off the back side of the laptop.
      • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
      Pergunte ao FixBot
      Comentar
    3. Asus X200MA Fan Replacement: passo 3, imagem 1 %32
      • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
      Pergunte ao FixBot
      Comentar
    1. Asus X200MA Fan Replacement, Battery: passo 4, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    2. Asus X200MA Fan Replacement: passo 5, imagem 1 %32
      • Remove the following two screws under the rubber caps.
      • Two 14 mm screws using the Phillips #0 screw driver.
      Pergunte ao FixBot
      Comentar
    3. Asus X200MA Fan Replacement: passo 6, imagem 1 %32
      • Flip up the following:
      • The two latches holding the two cables shown(white and black)
      • Pull the cables free from the latches
      • Lift the keyboard from the computer
      Pergunte ao FixBot
      Comentar
    4. Asus X200MA Fan Replacement: passo 7, imagem 1 %32
      • Remove the following screws from the inside of the laptop:
      • Two 4 mm screws using the Phillips #0 phillips screwdriver.
      • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
      Pergunte ao FixBot
      Comentar
    5. Asus X200MA Fan Replacement: passo 8, imagem 1 %32
      • Slide the battery up and out.
      Pergunte ao FixBot
      Comentar
    1. Asus X200MA Fan Replacement, Fan: passo 9, imagem 1 %32
      • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Asus X200MA Fan Replacement: passo 10, imagem 1 %32 Asus X200MA Fan Replacement: passo 10, imagem 2 %32
      • Unplug the set of wires located at bottom corner on fan.
      Pergunte ao FixBot
      Comentar
    3. Asus X200MA Fan Replacement: passo 11, imagem 1 %32 Asus X200MA Fan Replacement: passo 11, imagem 2 %32
      • Lift up and out to completely the remove fan component.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Vanessa Garcia
Membro desde: 01/22/15
1.817 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-24, Maness Winter 2015 Membro de Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Membros
Autoria de 71 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 28
Ao todo: 2,741
