Introdução
This guide will show you how to replace your fan and heatsink. This will restore the cooling capabilities of the laptop close to factory conditions. Before starting the steps make sure the Laptop is fully powered off.
O que você precisa
Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
Quase terminado!
Conclusão
