Introdução
This guide will show you how to remove the back panel and remove/replace the battery for the Asus VivoTab Smart tablet.
Once you are done, calibrate your newly installed battery by draining it below 10% and then charging it uninterrupted to 100%.
O que você precisa
Place the device face down on a flat surface.
Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
4 outras pessoas executaram este guia.
2Comentários do guia
Hi
So where is the next step ?!
Hi
Please answer to me. This is so
