Ir para o conteúdo principal
Asus VivoBook X202E-DB21T Power Port Replacement
O que você precisa
  1. Asus VivoBook X202E-DB21T Power Port Replacement, Battery: passo 1, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Power Port Replacement: passo 2, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement: passo 2, imagem 2 %32
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Power Port Replacement: passo 3, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement: passo 3, imagem 2 %32
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Power Port Replacement: passo 4, imagem 1 %32
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Power Port Replacement: passo 5, imagem 1 %32
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Power Port Replacement, Hard Drive: passo 6, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement, Hard Drive: passo 6, imagem 2 %32
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Power Port Replacement: passo 7, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement: passo 7, imagem 2 %32
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
  8. Asus VivoBook X202E-DB21T Power Port Replacement, Motherboard: passo 8, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement, Motherboard: passo 8, imagem 2 %32
    • Unscrew the five 5mm screws holding the left board together.
  9. Asus VivoBook X202E-DB21T Power Port Replacement: passo 9, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement: passo 9, imagem 2 %32
    • Unplug the two connectors on the left board.
  10. Asus VivoBook X202E-DB21T Power Port Replacement: passo 10, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement: passo 10, imagem 2 %32 Asus VivoBook X202E-DB21T Power Port Replacement: passo 10, imagem 3 %32
    • Remove the single 3mm screw from the sound chip.
    • Unplug the sound chip.
    • Remove the sound chip.
  11. Asus VivoBook X202E-DB21T Power Port Replacement: passo 11, imagem 1 %32
    • Remove the six 4mm screws holding the fan and CPU cover.
  12. Asus VivoBook X202E-DB21T Power Port Replacement: passo 12, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement: passo 12, imagem 2 %32
    • Unplug the fan.
    • Remove the fan and CPU cover.
  13. Asus VivoBook X202E-DB21T Power Port Replacement: passo 13, imagem 1 %32
    • Unscrew the nine 4mm screws holding the right board together.
  14. Asus VivoBook X202E-DB21T Power Port Replacement: passo 14, imagem 1 %32
    • Remove the two remaining connectors on the board.
  15. Asus VivoBook X202E-DB21T Power Port Replacement: passo 15, imagem 1 %32
    • Remove the right board.
  16. Asus VivoBook X202E-DB21T Power Port Replacement, Power Port: passo 16, imagem 1 %32
    • Locate the power port on the right board near the internet port.
  17. Asus VivoBook X202E-DB21T Power Port Replacement: passo 17, imagem 1 %32 Asus VivoBook X202E-DB21T Power Port Replacement: passo 17, imagem 2 %32
    • De-solder the pins of the port from the board
    • See this guide on how to use a soldering iron.
    • Remove the port from the board.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 968
