Ir para o conteúdo principal
Asus UL80J Key Replacement
O que você precisa
    1. Asus UL80J Key Replacement, Battery: passo 1, imagem 1 %32
      • Place laptop face down with battery facing up.
      Pergunte ao FixBot
      Comentar
    2. Asus UL80J Key Replacement: passo 2, imagem 1 %32
      • Slide unlock button to the right.
      Pergunte ao FixBot
      Comentar
    3. Asus UL80J Key Replacement: passo 3, imagem 1 %32 Asus UL80J Key Replacement: passo 3, imagem 2 %32 Asus UL80J Key Replacement: passo 3, imagem 3 %32
      • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
      Pergunte ao FixBot
      Comentar
    1. Asus UL80J Key Replacement, Keyboard: passo 4, imagem 1 %32
      • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
      Pergunte ao FixBot
      Comentar
    2. Asus UL80J Key Replacement: passo 5, imagem 1 %32
      Ferramenta utilizada neste passo:
      Plastic Cards
      $2.99
      • Gently pry the keyboard up. This will allow you to unclip the keyboard.
      • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
      • Unclipping sounds are normal.
      Pergunte ao FixBot
      Comentar
      • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
      Pergunte ao FixBot
      Comentar
    3. Asus UL80J Key Replacement: passo 7, imagem 1 %32
      • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
      • Remove the tape from the ribbon cable if needed and remove the keyboard.
      Pergunte ao FixBot
      Comentar
    1. Asus UL80J Key Replacement, Key: passo 8, imagem 1 %32 Asus UL80J Key Replacement, Key: passo 8, imagem 2 %32
      • Gently insert the plastic opening tool between the key cap and the hinge. Slowly push the screwdriver up. The key should pop up easily.
      Pergunte ao FixBot
      Comentar
      • Clean the surface underneath the key with a soft brush or condensed air.
      Pergunte ao FixBot
      Comentar
      • Insert the new key in place of the old key. Ensure the clipping sound occurs.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team S2-G4, Lacy Spring 2017 Membro de USF Tampa, Team S2-G4, Lacy Spring 2017
USFT-LACY-S17S2G4
3 Membros
Autoria de 49 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 572
