Ir para o conteúdo principal
Asus Transformer T100 Button Module Replacement
O que você precisa
    1. Asus Transformer T100 Button Module Replacement, Rear Cover: passo 1, imagem 1 %32 Asus Transformer T100 Button Module Replacement, Rear Cover: passo 1, imagem 2 %32
      • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
      • Remove the tablet by lifting up.
      Pergunte ao FixBot
      Comentar
    2. Asus Transformer T100 Button Module Replacement: passo 2, imagem 1 %32 Asus Transformer T100 Button Module Replacement: passo 2, imagem 2 %32
      • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
      • With a little force, you will feel the clips release.
      Pergunte ao FixBot
      Comentar
    3. Asus Transformer T100 Button Module Replacement: passo 3, imagem 1 %32
      • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
      • Do not break these clips; otherwise, the screen will become less secure.
      Pergunte ao FixBot
      Comentar
    4. Asus Transformer T100 Button Module Replacement: passo 4, imagem 1 %32 Asus Transformer T100 Button Module Replacement: passo 4, imagem 2 %32
      • Remove the rear casing.
      Pergunte ao FixBot
      Comentar
    1. Asus Transformer T100 Button Module Replacement, Button Module: passo 5, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Unclip the white connection clip using a pair of tweezers.
      Pergunte ao FixBot
      Comentar
    2. Asus Transformer T100 Button Module Replacement: passo 6, imagem 1 %32 Asus Transformer T100 Button Module Replacement: passo 6, imagem 2 %32
      • Pull the connection apparatus from the connection clip on the board using a pair of tweezers.
      Pergunte ao FixBot
      Comentar
    3. Asus Transformer T100 Button Module Replacement: passo 7, imagem 1 %32
      • Gently fold the connection apparatus back away from your work area.
      Pergunte ao FixBot
      Comentar
    4. Asus Transformer T100 Button Module Replacement: passo 8, imagem 1 %32 Asus Transformer T100 Button Module Replacement: passo 8, imagem 2 %32 Asus Transformer T100 Button Module Replacement: passo 8, imagem 3 %32
      • Remove the screws using a Phillips Head #1 screwdriver.
      • Remove the power button module.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Taylor Pantiga
Membro desde: 04/14/14
1.629 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-31, Maness Spring 2014 Membro de Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Membros
Autoria de 42 guias
1Comentário do guia
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
Rudolf Guys - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 36
Ao todo: 6,583
