Ir para o conteúdo principal
Asus Transformer T100 Battery Replacement
O que você precisa
    1. Asus Transformer T100 Battery Replacement, Rear Cover: passo 1, imagem 1 %32 Asus Transformer T100 Battery Replacement, Rear Cover: passo 1, imagem 2 %32
      • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
      • Remove the tablet by lifting up.
      Pergunte ao FixBot
      Comentar
    2. Asus Transformer T100 Battery Replacement: passo 2, imagem 1 %32 Asus Transformer T100 Battery Replacement: passo 2, imagem 2 %32
      • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
      • With a little force, you will feel the clips release.
      Pergunte ao FixBot
      Comentar
    3. Asus Transformer T100 Battery Replacement: passo 3, imagem 1 %32
      • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
      • Do not break these clips; otherwise, the screen will become less secure.
      Pergunte ao FixBot
      Comentar
    4. Asus Transformer T100 Battery Replacement: passo 4, imagem 1 %32 Asus Transformer T100 Battery Replacement: passo 4, imagem 2 %32
      • Remove the rear casing.
      Pergunte ao FixBot
      Comentar
    1. Asus Transformer T100 Battery Replacement, Battery: passo 5, imagem 1 %32
      • Remove the copper tape carefully.
      Pergunte ao FixBot
      Comentar
    2. Asus Transformer T100 Battery Replacement: passo 6, imagem 1 %32 Asus Transformer T100 Battery Replacement: passo 6, imagem 2 %32
      • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
      Pergunte ao FixBot
      Comentar
    3. Asus Transformer T100 Battery Replacement: passo 7, imagem 1 %32 Asus Transformer T100 Battery Replacement: passo 7, imagem 2 %32 Asus Transformer T100 Battery Replacement: passo 7, imagem 3 %32
      • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
      • The battery wire harness will slide out as the battery is pried up.
      Pergunte ao FixBot
      Comentar
    4. Asus Transformer T100 Battery Replacement: passo 8, imagem 1 %32 Asus Transformer T100 Battery Replacement: passo 8, imagem 2 %32
      • Remove the battery by slowly peeling the battery away from the connected side.
      • The adhesive on the back will pull away from the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
70 outras pessoas executaram este guia.
Taylor Pantiga
Membro desde: 04/14/14
1.629 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-31, Maness Spring 2014 Membro de Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Membros
Autoria de 48 guias
22Comentários do guia
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
christian cantu - Responder Compartilhar
Hi christian! How did you solve this problem? That happened to me too...
Matheus Moraes - Responder Compartilhar
what is the battery part # for t100 and can you purchase it?
thank you
RJ - Responder Compartilhar
Part number is C12N1320. They are available from a variety of sources.
Jack Riggins - Responder Compartilhar
Thanks for detailed guide.
I could not get the transformer tablet to power up no matter which buttons I held for how long or in what sequence. Unplugging the battery internally and replugging fixed a hung device.
JPWhite - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 41
Últimos 30 dias: 189
Ao todo: 133,458
