Ir para o conteúdo principal
Asus Transformer Pad Infinity Glass Replacement
O que você precisa
  1. Asus Transformer Pad Infinity Glass Replacement, Glass: passo 1, imagem 1 %32 Asus Transformer Pad Infinity Glass Replacement, Glass: passo 1, imagem 2 %32 Asus Transformer Pad Infinity Glass Replacement, Glass: passo 1, imagem 3 %32
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
    Pergunte ao FixBot
    Comentar
  2. Asus Transformer Pad Infinity Glass Replacement: passo 2, imagem 1 %32
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
    Pergunte ao FixBot
    Comentar
  3. Asus Transformer Pad Infinity Glass Replacement: passo 3, imagem 1 %32
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
    Pergunte ao FixBot
    Comentar
  4. Asus Transformer Pad Infinity Glass Replacement: passo 4, imagem 1 %32
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
    Pergunte ao FixBot
    Comentar
  5. Asus Transformer Pad Infinity Glass Replacement: passo 5, imagem 1 %32
    • Once removed, replace the glass screen back onto the LCD display.
    • The new screen may or may not have new adhesive depending on where you got it. If it doesn’t, make sure you secure it with the screws safely.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Allison Poh
Membro desde: 10/20/15
549 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 1,142
