Ir para o conteúdo principal
Asus Transformer Pad Infinity Charging Port Replacement
O que você precisa
    1. Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: passo 1, imagem 2 %32
      • Take off the screen and the big motherboard.
      Pergunte ao FixBot
      Comentar
    2. Asus Transformer Pad Infinity Charging Port Replacement: passo 2, imagem 1 %32 Asus Transformer Pad Infinity Charging Port Replacement: passo 2, imagem 2 %32 Asus Transformer Pad Infinity Charging Port Replacement: passo 2, imagem 3 %32
      • Disconnect the long silver ribbon connector from the screen.
      • Remove the orange ribbon connector with the two connections.
      Pergunte ao FixBot
      Comentar
    3. Asus Transformer Pad Infinity Charging Port Replacement: passo 3, imagem 1 %32
      • Flip up the piece securing the ribbon to the big motherboard and remove the ribbon from the motherboard.
      • Note: This will have tape covering it, make sure not to cut the ribbon or scratch any other parts if you are looking to preserve these things.
      Pergunte ao FixBot
      Comentar
    4. Asus Transformer Pad Infinity Charging Port Replacement: passo 4, imagem 1 %32
      • Remove the two screws holding the actual port, that goes to the outside of the device, in. This piece will be connected to the case.
      Pergunte ao FixBot
      Comentar
    5. Asus Transformer Pad Infinity Charging Port Replacement: passo 5, imagem 1 %32
      • Once removing the damaged charging port, put in your new part and reassemble the device and check if the new charging port works.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Allison Poh
Membro desde: 10/20/15
549 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 21
Ao todo: 1,539
