Ir para o conteúdo principal
Asus Transformer Book T100TAF Battery Replacement
O que você precisa
  1. Asus Transformer Book T100TAF Battery Replacement, Battery: passo 1, imagem 1 %32
    • Detach the keyboard from the screen by depressing the silver button the hinge and pulling upwards on the tablet.
    Pergunte ao FixBot
    Comentar
  2. Asus Transformer Book T100TAF Battery Replacement: passo 2, imagem 1 %32
    • Take the tablet-portion of the device and carefully pry the screen open using either the plastic or metal spudger. Each interior clip needs to be released from the edges.
    Pergunte ao FixBot
    Comentar
  3. Asus Transformer Book T100TAF Battery Replacement: passo 3, imagem 1 %32 Asus Transformer Book T100TAF Battery Replacement: passo 3, imagem 2 %32
    • Remove the plastic backing from the device and locate the battery pack.
    • Battery pack
    Pergunte ao FixBot
    Comentar
  4. Asus Transformer Book T100TAF Battery Replacement: passo 4, imagem 1 %32 Asus Transformer Book T100TAF Battery Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to pry the battery up from the device. Pry from different sides of the battery to loosen and break the glue that is holding it down.
    • The battery cable will release as the battery is removed from the device.
    • Be sure to recycle your old battery.
    • Do not puncture or bend the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. After replacement, it is advised to calibrate your new battery by fully draining the battery and then charging it, uninterrupted, to 100%.
6 outras pessoas executaram este guia.
Elizabeth
Membro desde: 10/01/16
589 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 4-3, Passmore Fall 2016 Membro de USF Tampa, Team 4-3, Passmore Fall 2016
USFT-PASSMORE-F16S4G3
4 Membros
Autoria de 10 guias
3Comentários do guia
Bonjour
Remplacement sans problème pour un ASUS T200TA
Par contre il a perdu le paramétrage du Boot.
Ou puis je retrouver ce parametrage??
jp.boubal - Responder Compartilhar
Bonjour quelqu’un sait comment retirer la batterie d’origine de l’ordinateur (au niveau de la connection)?
Merci
Pierre-Alain Gallion - Responder Compartilhar
Hi
What glue did you use to secure the new battery?
Thank you
Paul
Paul - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 64
Ao todo: 17,528
