Ir para o conteúdo principal
Asus ROG Strix GL702VS Trackpad Replacement
O que você precisa
  1. Asus ROG Strix GL702VS Trackpad Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip the computer so the bottom of the laptop is facing up.
    Pergunte ao FixBot
    Comentar
  2. Asus ROG Strix GL702VS Trackpad Replacement: passo 2, imagem 1 %32
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
    Pergunte ao FixBot
    Comentar
  3. Asus ROG Strix GL702VS Trackpad Replacement: passo 3, imagem 1 %32 Asus ROG Strix GL702VS Trackpad Replacement: passo 3, imagem 2 %32
    • Use a Jimmy to carefully free each side of the bottom casing.
    Pergunte ao FixBot
    Comentar
  4. Asus ROG Strix GL702VS Trackpad Replacement: passo 4, imagem 1 %32
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
    Pergunte ao FixBot
    Comentar
  5. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: passo 5, imagem 1 %32 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: passo 5, imagem 2 %32 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: passo 5, imagem 3 %32
    • Disconnect the ribbon cables from the connectors at the bottom of the motherboard by lifting up the tabs with a nylon spudger tool.
    • Slide the ribbon cables out of the connectors on the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Asus ROG Strix GL702VS Trackpad Replacement: passo 6, imagem 1 %32 Asus ROG Strix GL702VS Trackpad Replacement: passo 6, imagem 2 %32
    • Remove the covering foil holding the trackpad into place.
    • Completely peel the foil back to ensure it does not interfere with the following processes.
    Pergunte ao FixBot
    Comentar
  7. Asus ROG Strix GL702VS Trackpad Replacement: passo 7, imagem 1 %32 Asus ROG Strix GL702VS Trackpad Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Lift up speaker cable that is laying overtop using a pair of tweezers.
    • Do not to overextend the wire since you may accidently pull the wire out.
    Pergunte ao FixBot
    Comentar
  8. Asus ROG Strix GL702VS Trackpad Replacement: passo 8, imagem 1 %32 Asus ROG Strix GL702VS Trackpad Replacement: passo 8, imagem 2 %32 Asus ROG Strix GL702VS Trackpad Replacement: passo 8, imagem 3 %32
    • Remove the three 4mm JIS #0 screws that are securing the trackpad.
    Pergunte ao FixBot
    Comentar
  9. Asus ROG Strix GL702VS Trackpad Replacement: passo 9, imagem 1 %32 Asus ROG Strix GL702VS Trackpad Replacement: passo 9, imagem 2 %32
    • Once freed, slide the trackpad backwards towards the center of laptop.
    • This may require some jiggling. Lifting the laptop off your working surface may help.
    • Sliding the trackpad back in can be a bit tricky. Ensure it is fully seated before continuing reassembly.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 35
Ao todo: 1,364
