Introdução
A wireless card is used to connect a computer to a wireless network (Wi-Fi).
If your Asus ROG G752V is giving a blue screen or the wireless card is damaged, this means that the wireless connection is not working and a repair is needed.
Before starting the guide below, it is important to disconnect the charger from the laptop and make sure that the laptop is completely shut off before starting.
Be sure to have all the specified tools that are listed below before starting the replacement process.
Now follow these steps below in order to fix the issue.
O que você precisa
Using a pair of tweezers, remove all 11 rubber plugs off of the back cover.
