Ir para o conteúdo principal
Asus ROG Ally SSD Replacement
O que você precisa
  1. Asus ROG Ally SSD Replacement, Prepare your device for disassembly: passo 1, imagem 1 %32 Asus ROG Ally SSD Replacement, Prepare your device for disassembly: passo 1, imagem 2 %32 Asus ROG Ally SSD Replacement, Prepare your device for disassembly: passo 1, imagem 3 %32
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Asus ROG Ally SSD Replacement, Unfasten the back cover: passo 2, imagem 1 %32 Asus ROG Ally SSD Replacement, Unfasten the back cover: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Asus ROG Ally SSD Replacement, Insert an opening pick: passo 3, imagem 1 %32 Asus ROG Ally SSD Replacement, Insert an opening pick: passo 3, imagem 2 %32 Asus ROG Ally SSD Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Asus ROG Ally SSD Replacement, Release the back cover's clips: passo 4, imagem 1 %32 Asus ROG Ally SSD Replacement, Release the back cover's clips: passo 4, imagem 2 %32 Asus ROG Ally SSD Replacement, Release the back cover's clips: passo 4, imagem 3 %32
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Asus ROG Ally SSD Replacement, Remove the back cover: passo 5, imagem 1 %32 Asus ROG Ally SSD Replacement, Remove the back cover: passo 5, imagem 2 %32 Asus ROG Ally SSD Replacement, Remove the back cover: passo 5, imagem 3 %32
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Asus ROG Ally SSD Replacement, Remove the plastic cover: passo 6, imagem 1 %32 Asus ROG Ally SSD Replacement, Remove the plastic cover: passo 6, imagem 2 %32 Asus ROG Ally SSD Replacement, Remove the plastic cover: passo 6, imagem 3 %32
    • Use your fingers to peel up and remove the black plastic cover between the fans.
    • Put the cover aside—you'll use it during reassembly.
  7. Asus ROG Ally SSD Replacement, Unlatch the locking bar: passo 7, imagem 1 %32 Asus ROG Ally SSD Replacement, Unlatch the locking bar: passo 7, imagem 2 %32 Asus ROG Ally SSD Replacement, Unlatch the locking bar: passo 7, imagem 3 %32
    • A metal locking bar secures the top edge of the battery connector
    • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
  8. Asus ROG Ally SSD Replacement, Disconnect the battery: passo 8, imagem 1 %32 Asus ROG Ally SSD Replacement, Disconnect the battery: passo 8, imagem 2 %32 Asus ROG Ally SSD Replacement, Disconnect the battery: passo 8, imagem 3 %32
    • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
    • Insert the flat end of a spudger under the center of the battery connector.
    • Lift the connector straight up and out of its socket to disconnect the battery.
    • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
  9. Asus ROG Ally SSD Replacement, Unfasten the SSD: passo 9, imagem 1 %32 Asus ROG Ally SSD Replacement, Unfasten the SSD: passo 9, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 3.4 mm‑long screw securing the SSD.
  10. Asus ROG Ally SSD Replacement, Remove the SSD: passo 10, imagem 1 %32 Asus ROG Ally SSD Replacement, Remove the SSD: passo 10, imagem 2 %32
    • If you have trouble removing the SSD, you can remove the battery for easier access.
    • Grip the bottom corners of the SSD and slightly lift until it clears the screw post.
    • Do not lift more than this or you may damage the SSD and its socket.
    • Pull the SSD straight out of its socket and remove it.
  11. Asus ROG Ally SSD Replacement: passo 11, imagem 1 %32 Asus ROG Ally SSD Replacement: passo 11, imagem 2 %32
    • Once you've reassembled your device:
    • Plug your device in and turn it on. It should boot into the BIOS menu.
    • Navigate to the Advanced tab and click ASUS Cloud Recovery.
    • Follow the prompts to finish setting up your device.
Conclusão
7 outras pessoas executaram este guia.
Spencer Day
Membro desde: 09/14/22
150.284 Reputação
Autoria de 995 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.654 guias
1Comentário do guia
Hi Spencer. Look, I wanted to ask you a question, it turns out that my Asus rog ally is stuck on its home screen, as if it could not boot, I checked everything, disk, motherboard and everything is in order, I imagine the bios menu is broken, you could help me with that?
Sebastian - Responder
Comentar
Visualizações:
Últimas 24 horas: 24
Últimos 7 dias: 151
Últimos 30 dias: 919
Ao todo: 19,495
