Ir para o conteúdo principal
Asus Q551L Repair Optical Drive Replacement
O que você precisa
  1. Asus Q551L Repair Optical Drive Replacement, Back Panel: passo 1, imagem 1 %32 Asus Q551L Repair Optical Drive Replacement, Back Panel: passo 1, imagem 2 %32
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
    Pergunte ao FixBot
    Comentar
  2. Asus Q551L Repair Optical Drive Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
    Pergunte ao FixBot
    Comentar
  3. Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): passo 3, imagem 1 %32 Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): passo 3, imagem 2 %32 Asus Q551L Repair Optical Drive Replacement, Optical Drive (PN UJ8E2): passo 3, imagem 3 %32
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 995
