Ir para o conteúdo principal
Asus Q534U RAM Replacement
O que você precisa
  1. Asus Q534U RAM Replacement, Back Case Removal: passo 1, imagem 1 %32
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
    Pergunte ao FixBot
    Comentar
  2. Asus Q534U RAM Replacement: passo 2, imagem 1 %32 Asus Q534U RAM Replacement: passo 2, imagem 2 %32
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
    Pergunte ao FixBot
    Comentar
  3. Asus Q534U RAM Replacement: passo 3, imagem 1 %32 Asus Q534U RAM Replacement: passo 3, imagem 2 %32
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
    Pergunte ao FixBot
    Comentar
  4. Asus Q534U RAM Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
    Pergunte ao FixBot
    Comentar
  5. Asus Q534U RAM Replacement, RAM: passo 5, imagem 1 %32 Asus Q534U RAM Replacement, RAM: passo 5, imagem 2 %32 Asus Q534U RAM Replacement, RAM: passo 5, imagem 3 %32
    • Locate the metal RAM cover
    • Pull the metal tab on the corner of the metal cover to lift the cover from its clips
    • A pry tool may provide a better grip on small tab.
    Pergunte ao FixBot
    Comentar
  6. Asus Q534U RAM Replacement: passo 6, imagem 1 %32 Asus Q534U RAM Replacement: passo 6, imagem 2 %32 Asus Q534U RAM Replacement: passo 6, imagem 3 %32
    • While pushing out the metal clips on both sides of the RAM, lift up the RAM to release it
    • Pull the RAM out gently and bring it up from the slot
    • Make sure to pull out first and then pull the RAM up out of place
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Kyle Whalen
Membro desde: 10/17/17
181 Reputação
Autoria de 1 guia
4Comentários do guia
One question: I have this model and have determined that I have a bad stick of RAM. I have removed this stick but still have 8 gigs available. Is there another stick that I m not seeing or is this built in?
Elijah Elliott - Responder Compartilhar
saame here must be another stick somewhere
SvGGRK - Responder Compartilhar
There are 4, 2GB chips of ram, hard built into the motherboard. Located right above the SSD m.2 bay, and beside the copper cooling line. This model of Laptop has one RAM bay, I'm not sure how the Built in and Bay RAM work together but for all intents and purposes, just assume you are only using the Bay for RAM. @svggrk @elijahelliott
Nirlicnick - Responder Compartilhar
This is too old but I hope someone can help me. I open the memory section just to clean all the dust accumulated there. After putting everything back laptop is bricked... Battery led is green. Power led is on but laptop is not booting. Any ideas?
Mario Venegas - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 53
Ao todo: 8,243
