Ir para o conteúdo principal
Asus Q534U Motherboard Replacement
O que você precisa
    1. Asus Q534U Motherboard Replacement, Back Case: passo 1, imagem 1 %32 Asus Q534U Motherboard Replacement, Back Case: passo 1, imagem 2 %32 Asus Q534U Motherboard Replacement, Back Case: passo 1, imagem 3 %32
      • Remove ten screws with the T5 driver.
      • Use the opening tool to carefully pry off the back case.
      Pergunte ao FixBot
      Comentar
    1. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: passo 2, imagem 1 %32 Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: passo 2, imagem 2 %32
      • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
      Pergunte ao FixBot
      Comentar
    2. Asus Q534U Motherboard Replacement: passo 3, imagem 1 %32 Asus Q534U Motherboard Replacement: passo 3, imagem 2 %32
      • Move the black cable located around the CPU fan out of the holder.
      • Remove the following 9 screws:
      • Three Phillips screws
      • Six Phillips screws
      • Make sure not to mix up both types of screws.
      • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
      • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
      Pergunte ao FixBot
      Comentar
    1. Asus Q534U Motherboard Replacement, Hard Drive: passo 4, imagem 1 %32 Asus Q534U Motherboard Replacement, Hard Drive: passo 4, imagem 2 %32
      • Remove four screws with the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Asus Q534U Motherboard Replacement: passo 5, imagem 1 %32 Asus Q534U Motherboard Replacement: passo 5, imagem 2 %32
      • Gently lift the hard disk out using the black tab.
      Pergunte ao FixBot
      Comentar
    3. Asus Q534U Motherboard Replacement: passo 6, imagem 1 %32
      • Using a Phillips #00 screwdriver remove the four screws of the metal casing
      • Remove the hard disk from the metal casing
      Pergunte ao FixBot
      Comentar
    1. Asus Q534U Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Asus Q534U Motherboard Replacement, Motherboard: passo 7, imagem 2 %32 Asus Q534U Motherboard Replacement, Motherboard: passo 7, imagem 3 %32
      • Disconnect the four marked cables connectors at the sockets.
      Pergunte ao FixBot
      Comentar
    2. Asus Q534U Motherboard Replacement: passo 8, imagem 1 %32 Asus Q534U Motherboard Replacement: passo 8, imagem 2 %32 Asus Q534U Motherboard Replacement: passo 8, imagem 3 %32
      • Lift the connecting ports up prior to removing the connectors.
      Pergunte ao FixBot
      Comentar
    3. Asus Q534U Motherboard Replacement: passo 9, imagem 1 %32 Asus Q534U Motherboard Replacement: passo 9, imagem 2 %32 Asus Q534U Motherboard Replacement: passo 9, imagem 3 %32
      • Remove the screws holding the hinges down on both sides of the device.
      • A pry tool might be needed to lift the hinge.
      Pergunte ao FixBot
      Comentar
    4. Asus Q534U Motherboard Replacement: passo 10, imagem 1 %32
      • Remove nine, 3.2 mm screws to fully release motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Jacob Pauker
Membro desde: 09/03/19
238 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G9, Hovde Fall 2019 Membro de IUPUI, Team S1-G9, Hovde Fall 2019
IUPUI-HOVDE-F19S1G9
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 58
Ao todo: 2,720
