Ir para o conteúdo principal
Asus Q525U RAM Replacement
O que você precisa
  1. Asus Q525U RAM Replacement, Back Cover: passo 1, imagem 1 %32 Asus Q525U RAM Replacement, Back Cover: passo 1, imagem 2 %32 Asus Q525U RAM Replacement, Back Cover: passo 1, imagem 3 %32
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Asus Q525U RAM Replacement: passo 2, imagem 1 %32 Asus Q525U RAM Replacement: passo 2, imagem 2 %32 Asus Q525U RAM Replacement: passo 2, imagem 3 %32
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    Pergunte ao FixBot
    Comentar
  3. Asus Q525U RAM Replacement: passo 3, imagem 1 %32 Asus Q525U RAM Replacement: passo 3, imagem 2 %32 Asus Q525U RAM Replacement: passo 3, imagem 3 %32
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    Pergunte ao FixBot
    Comentar
  4. Asus Q525U RAM Replacement, RAM: passo 4, imagem 1 %32
    • Position the flat end of the Spudger under one of the corners on the RAM cover and pry it up slightly.
    • Move the spudger around the periphery of the cover to lift the cover up.
    Pergunte ao FixBot
    Comentar
  5. Asus Q525U RAM Replacement: passo 5, imagem 1 %32
    • Lift the RAM cover off.
    • The RAM should now be fully exposed.
    Pergunte ao FixBot
    Comentar
  6. Asus Q525U RAM Replacement: passo 6, imagem 1 %32 Asus Q525U RAM Replacement: passo 6, imagem 2 %32 Asus Q525U RAM Replacement: passo 6, imagem 3 %32
    • Using a spudger or your fingers, gently pull the metal brackets away from the RAM.
    • After pulling both brackets away from the component, the RAM should release at an upward angle (allowing for removal and replacement).
    Pergunte ao FixBot
    Comentar
  7. Asus Q525U RAM Replacement: passo 7, imagem 1 %32
    • Slide the RAM stick out of the socket.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 2-5, Hunter Spring 2022 Membro de Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 1,591
