Ir para o conteúdo principal
Asus Q525U Hard Drive Replacement
O que você precisa
  1. Asus Q525U Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32 Asus Q525U Hard Drive Replacement, Back Cover: passo 1, imagem 2 %32 Asus Q525U Hard Drive Replacement, Back Cover: passo 1, imagem 3 %32
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Asus Q525U Hard Drive Replacement: passo 2, imagem 1 %32 Asus Q525U Hard Drive Replacement: passo 2, imagem 2 %32 Asus Q525U Hard Drive Replacement: passo 2, imagem 3 %32
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    Pergunte ao FixBot
    Comentar
  3. Asus Q525U Hard Drive Replacement: passo 3, imagem 1 %32 Asus Q525U Hard Drive Replacement: passo 3, imagem 2 %32 Asus Q525U Hard Drive Replacement: passo 3, imagem 3 %32
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    Pergunte ao FixBot
    Comentar
  4. Asus Q525U Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • The hard drive is located to the left of the battery and below the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Asus Q525U Hard Drive Replacement: passo 5, imagem 1 %32 Asus Q525U Hard Drive Replacement: passo 5, imagem 2 %32
    • Remove the two 4 mm Phillips #1 screws which are holding the hard drive cover in place.
    Pergunte ao FixBot
    Comentar
  6. Asus Q525U Hard Drive Replacement: passo 6, imagem 1 %32 Asus Q525U Hard Drive Replacement: passo 6, imagem 2 %32
    • The hard drive cover is now easily accessible.
    • Lift the cover off, exposing the hard drive underneath [this laptop is missing its hard drive].
    • If replacing the hard drive, lift it up on the right side slightly and pull it from the connecter on the left.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Clemson, Team 2-5, Hunter Spring 2022 Membro de Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 3,746
