Ir para o conteúdo principal
Asus Q525U Battery Replacement
O que você precisa
  1. Asus Q525U Battery Replacement, Back Cover: passo 1, imagem 1 %32 Asus Q525U Battery Replacement, Back Cover: passo 1, imagem 2 %32 Asus Q525U Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Asus Q525U Battery Replacement: passo 2, imagem 1 %32 Asus Q525U Battery Replacement: passo 2, imagem 2 %32 Asus Q525U Battery Replacement: passo 2, imagem 3 %32
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    Pergunte ao FixBot
    Comentar
  3. Asus Q525U Battery Replacement: passo 3, imagem 1 %32 Asus Q525U Battery Replacement: passo 3, imagem 2 %32 Asus Q525U Battery Replacement: passo 3, imagem 3 %32
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    Pergunte ao FixBot
    Comentar
  4. Asus Q525U Battery Replacement, Battery: passo 4, imagem 1 %32 Asus Q525U Battery Replacement, Battery: passo 4, imagem 2 %32 Asus Q525U Battery Replacement, Battery: passo 4, imagem 3 %32
    • The battery of the device is outlined in red.
    • Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
    Pergunte ao FixBot
    Comentar
  5. Asus Q525U Battery Replacement: passo 5, imagem 1 %32 Asus Q525U Battery Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    Halberd Spudger
    $2.99
    • Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Asus Q525U Battery Replacement: passo 6, imagem 1 %32
    • Lift the battery out of the frame to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 2-5, Hunter Spring 2022 Membro de Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 61
Ao todo: 1,974
