Ir para o conteúdo principal
Asus Q525U Back Cover Replacement
O que você precisa
    1. Asus Q525U Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Asus Q525U Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Asus Q525U Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
      • Begin by powering off the device and flipping the device over.
      • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
      • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
      Pergunte ao FixBot
      Comentar
    2. Asus Q525U Back Cover Replacement: passo 2, imagem 1 %32 Asus Q525U Back Cover Replacement: passo 2, imagem 2 %32 Asus Q525U Back Cover Replacement: passo 2, imagem 3 %32
      • Use an opening pick to separate the back cover from the device.
      • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
      Pergunte ao FixBot
      Comentar
    3. Asus Q525U Back Cover Replacement: passo 3, imagem 1 %32 Asus Q525U Back Cover Replacement: passo 3, imagem 2 %32 Asus Q525U Back Cover Replacement: passo 3, imagem 3 %32
      • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
      • The back cover should be easily removable, allowing full access to all of the internal components.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 2-5, Hunter Spring 2022 Membro de Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Membros
Autoria de 38 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 1,170
