Ir para o conteúdo principal
Asus Q500A RAM Replacement
O que você precisa
  1. Asus Q500A RAM Replacement, RAM: passo 1, imagem 1 %32 Asus Q500A RAM Replacement, RAM: passo 1, imagem 2 %32
    • Flip device upside-down.
    • Remove back-plate by unscrewing the two screws on either side of the back-plate.
    • Remove the plastic cover.
    Pergunte ao FixBot
    Comentar
  2. Asus Q500A RAM Replacement: passo 2, imagem 1 %32
    • Depending on the model of the device, there will either be one or two sticks of ram.
    • There are two metal brackets holding each ram stick in.
    • To unlock the RAM, you'll need to remove the metal brackets. To do this, carefully push out the brackets.
    Pergunte ao FixBot
    Comentar
  3. Asus Q500A RAM Replacement: passo 3, imagem 1 %32 Asus Q500A RAM Replacement: passo 3, imagem 2 %32
    • Now simply remove the ram by pulling it out using a set of pliers to be safe and careful not to damage the ram.
    Pergunte ao FixBot
    Comentar
  4. Asus Q500A RAM Replacement: passo 4, imagem 1 %32
    • To insert the ram line up the ram stick and the slot.
    • Next you will have to push the ram down until it snaps into place.
    • Be careful not to do this too hard, as it can break the ram.
    • Make sure the ram is secure in its slot before moving on to the next piece of ram or replacing the back-plate.
    Pergunte ao FixBot
    Comentar
Conclusão
cameron
Membro desde: 02/15/17
319 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 12-5, Eyestone Spring 2017 Membro de USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 1,085
