Ir para o conteúdo principal
Asus Padfone X Mini Camera Replacement
O que você precisa
  1. Asus Padfone X Mini Camera Replacement, Speaker: passo 1, imagem 1 %32
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
    Pergunte ao FixBot
    Comentar
  2. Asus Padfone X Mini Camera Replacement: passo 2, imagem 1 %32
    • Lift the battery out from the top of the device.
    Pergunte ao FixBot
    Comentar
  3. Asus Padfone X Mini Camera Replacement: passo 3, imagem 1 %32
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
    Pergunte ao FixBot
    Comentar
  4. Asus Padfone X Mini Camera Replacement: passo 4, imagem 1 %32
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
    Pergunte ao FixBot
    Comentar
  5. Asus Padfone X Mini Camera Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove speaker with standard tweezers to minimize damage, and replace.
    Pergunte ao FixBot
    Comentar
  6. Asus Padfone X Mini Camera Replacement, Screen: passo 6, imagem 1 %32
    • Detach the black connector on the left hand side of the motherboard.
    • Don't completely remove the black connector.
    Pergunte ao FixBot
    Comentar
  7. Asus Padfone X Mini Camera Replacement: passo 7, imagem 1 %32
    • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
    Pergunte ao FixBot
    Comentar
  8. Asus Padfone X Mini Camera Replacement: passo 8, imagem 1 %32 Asus Padfone X Mini Camera Replacement: passo 8, imagem 2 %32
    • Remove motherboard and replace screen.
    Pergunte ao FixBot
    Comentar
  9. Asus Padfone X Mini Camera Replacement, Camera: passo 9, imagem 1 %32
    • Turn over the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Asus Padfone X Mini Camera Replacement: passo 10, imagem 1 %32
    • Using tweezers pull out the connector that connects the camera to the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Asus Padfone X Mini Camera Replacement: passo 11, imagem 1 %32 Asus Padfone X Mini Camera Replacement: passo 11, imagem 2 %32
    • Take out the camera.
    • Put in the new camera by sliding the camera connector into the receiver.
    Pergunte ao FixBot
    Comentar
Conclusão
James Jackson
Membro desde: 09/18/18
97 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 498
