Ir para o conteúdo principal
Asus Padfone 2 Camera Replacement
O que você precisa
  1. Asus Padfone 2 Camera  Replacement, Power Down Device: passo 1, imagem 1 %32
    • Hold down the power button.
    Pergunte ao FixBot
    Comentar
  2. Asus Padfone 2 Camera  Replacement, Remove Back Plate: passo 2, imagem 1 %32 Asus Padfone 2 Camera  Replacement, Remove Back Plate: passo 2, imagem 2 %32 Asus Padfone 2 Camera  Replacement, Remove Back Plate: passo 2, imagem 3 %32
    • Use plastic opening tool to pry off the back cover of the phone.
    Pergunte ao FixBot
    Comentar
  3. Asus Padfone 2 Camera  Replacement, Battery Removal: passo 3, imagem 1 %32 Asus Padfone 2 Camera  Replacement, Battery Removal: passo 3, imagem 2 %32 Asus Padfone 2 Camera  Replacement, Battery Removal: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
    Pergunte ao FixBot
    Comentar
  4. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: passo 4, imagem 1 %32 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: passo 4, imagem 2 %32 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: passo 4, imagem 3 %32
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
    Pergunte ao FixBot
    Comentar
  5. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: passo 5, imagem 1 %32 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: passo 5, imagem 2 %32 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: passo 5, imagem 3 %32
    • Disconnect four plugs to the motherboard using tweezers.
    • Lift up green motherboard.
    Pergunte ao FixBot
    Comentar
  6. Asus Padfone 2 Camera  Replacement, Removing Camera: passo 6, imagem 1 %32 Asus Padfone 2 Camera  Replacement, Removing Camera: passo 6, imagem 2 %32
    • Remove camera from back of the motherboard with tweezers.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Erica
Membro desde: 09/25/14
482 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-4, Mcgee Fall 2014 Membro de USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 2,280
