Ir para o conteúdo principal
Asus Padfone 2 Battery Replacement
O que você precisa
  1. Asus Padfone 2 Battery Replacement, Power off phone: passo 1, imagem 1 %32
    • Hold down power button to shut off phone.
    Pergunte ao FixBot
    Comentar
  2. Asus Padfone 2 Battery Replacement, Remove back cover of phone: passo 2, imagem 1 %32 Asus Padfone 2 Battery Replacement, Remove back cover of phone: passo 2, imagem 2 %32
    • Use plastic opening tool to pry off the back cover of the phone.
    Pergunte ao FixBot
    Comentar
  3. Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, imagem 1 %32 Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, imagem 2 %32 Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Disconnect battery connecting cord using tweezers.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 5-4, Mcgee Fall 2014 Membro de USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Membros
Autoria de 7 guias
1Comentário do guia
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 44
Ao todo: 6,387
