Ir para o conteúdo principal
Asus PadFone S Front Facing Camera Replacement
O que você precisa
  1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: passo 1, imagem 1 %32
    • Place your thumb in the charging port and pry the back cover off of the phone.
    Pergunte ao FixBot
    Comentar
  2. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: passo 2, imagem 1 %32 Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: passo 2, imagem 2 %32
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
    Pergunte ao FixBot
    Comentar
  3. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: passo 3, imagem 1 %32 Asus PadFone S Front Facing Camera Replacement, Remove the Battery: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
    Pergunte ao FixBot
    Comentar
  4. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 1 %32 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 2 %32 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 3 %32
    • Once the Battery has been successfully removed, move on to the step 2.
    Pergunte ao FixBot
    Comentar
  5. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: passo 5, imagem 1 %32 Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: passo 5, imagem 2 %32
    • Disconnect the marked strips from the logic board using the tweezers.
    • Applying too much force may damage the strips/connectors.
    • Remember to remove speaker connection located at the bottom left hand corner.
    Pergunte ao FixBot
    Comentar
  6. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: passo 6, imagem 1 %32 Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: passo 6, imagem 2 %32
    • Disconnect the other two strips that connect the logic board to the phone.
    Pergunte ao FixBot
    Comentar
  7. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: passo 7, imagem 1 %32 Asus PadFone S Front Facing Camera Replacement, Remove The Camera: passo 7, imagem 2 %32
    • Turn over the logic board to locate the front camera.
    • Grasp the sides of the camera with the tweezers and carefully remove the camera from the logic board.
    • Applying to much force will damage the connective strip.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 1,808
