Ir para o conteúdo principal
Asus MeMO Pad 7 ME170C Motherboard Replacement
O que você precisa
    1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: passo 1, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: passo 1, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: passo 1, imagem 3 %32
      • Power off the device before disassembly.
      • Be gentle; excessive force can result in a damaged or cracked screen.
      • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
      Pergunte ao FixBot
      Comentar
    2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 2, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 2, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 2, imagem 3 %32
      • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
      Pergunte ao FixBot
      Comentar
    3. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 3, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 3, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 3, imagem 3 %32
      • Use the plastic opening tool to pry around the edges of the battery.
      • The battery should be laying freely in its port.
      • Lift the battery out of its port.
      Pergunte ao FixBot
      Comentar
    4. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 4, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 4, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 4, imagem 3 %32
      • Use a plastic opening tool to slide the white cable connector completely out of the port.
      Pergunte ao FixBot
      Comentar
    5. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 5, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 5, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 5, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Flip up the beige clip to loosen the cable.
      • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
      • Pull the blue tab gently in a lateral motion until it is completely out of its port.
      Pergunte ao FixBot
      Comentar
    6. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 6, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 6, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 6, imagem 3 %32
      • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
      Pergunte ao FixBot
      Comentar
    7. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 7, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 7, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 7, imagem 3 %32
      • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
      Pergunte ao FixBot
      Comentar
    8. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 8, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 8, imagem 2 %32
      • Use the Phillips #000 screwdriver to unscrew the seven screws.
      • There should be two silver and five black screws.
      Pergunte ao FixBot
      Comentar
    9. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 9, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 9, imagem 2 %32
      • Once the screws are removed, the speaker component will be loosely laying in the track.
      • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
      Pergunte ao FixBot
      Comentar
    10. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 10, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 10, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 10, imagem 3 %32
      • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
      Pergunte ao FixBot
      Comentar
    11. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 11, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 11, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 11, imagem 3 %32
      • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
      Pergunte ao FixBot
      Comentar
    12. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 12, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 12, imagem 2 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 12, imagem 3 %32
      • Use the Phillips #000 screwdriver to unscrew all five screws.
      Pergunte ao FixBot
      Comentar
    13. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 13, imagem 1 %32 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: passo 13, imagem 2 %32
      • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
1Comentário do guia
You are amazing!! Please make the tutorial "how change ASUS ME170 Touch Screen Digitizer". Thanks!!!
Walter Tejerina - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 3,770
