Ir para o conteúdo principal
Asus K55a-si50301p USB 3.0 Replacement
O que você precisa
  1. Asus K55a-si50301p USB 3.0 Replacement, Battery: passo 1, imagem 1 %32
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p USB 3.0 Replacement: passo 2, imagem 1 %32
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p USB 3.0 Replacement: passo 3, imagem 1 %32
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p USB 3.0 Replacement, USB 3.0/Audio Ports: passo 4, imagem 1 %32
    • Remove the eight Phillips #0 screws.
  5. Asus K55a-si50301p USB 3.0 Replacement: passo 5, imagem 1 %32
    • Gently pull towards yourself and up to remove the first plastic cover.
  6. Asus K55a-si50301p USB 3.0 Replacement: passo 6, imagem 1 %32 Asus K55a-si50301p USB 3.0 Replacement: passo 6, imagem 2 %32
    • Use the iFixit opening tool around the outside line where the top of the laptop meets the bottom to separate components.
  7. Asus K55a-si50301p USB 3.0 Replacement: passo 7, imagem 1 %32
    • Flip the laptop over and lift the keyboard tray gently towards the screen.
    • Remove the 3 ribbon cables from the motherboard end.
  8. Asus K55a-si50301p USB 3.0 Replacement: passo 8, imagem 1 %32
    • With the keyboard tray out of the way, remove the tape holding down the accessory board ribbon cable.
  9. Asus K55a-si50301p USB 3.0 Replacement: passo 9, imagem 1 %32
    • Pull the ribbon cable out of its slot on the USB/Audio port board as shown.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
after doing this start button lights up but will not boot
David Garside - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 676
