Ir para o conteúdo principal
Asus K55a-si50301p RAM Replacement
O que você precisa
  1. Asus K55a-si50301p RAM Replacement, Battery: passo 1, imagem 1 %32
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p RAM Replacement: passo 2, imagem 1 %32
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p RAM Replacement: passo 3, imagem 1 %32
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p RAM Replacement, Lower Back Panel: passo 4, imagem 1 %32
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p RAM Replacement: passo 5, imagem 1 %32
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p RAM Replacement: passo 6, imagem 1 %32
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p RAM Replacement, RAM: passo 7, imagem 1 %32
    • Press slot pins outwards with gentle force.
  8. Asus K55a-si50301p RAM Replacement: passo 8, imagem 1 %32
    • After the RAM stick pops up, pull it towards you to gently remove it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 475
