Ir para o conteúdo principal
Asus K50IJ Fan Replacement
O que você precisa
  1. Asus K50IJ Fan Replacement, Battery: passo 1, imagem 1 %32
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Asus K50IJ Fan Replacement: passo 2, imagem 1 %32 Asus K50IJ Fan Replacement: passo 2, imagem 2 %32 Asus K50IJ Fan Replacement: passo 2, imagem 3 %32
    • Lift the exposed lip and remove the battery cover.
    Pergunte ao FixBot
    Comentar
  3. Asus K50IJ Fan Replacement: passo 3, imagem 1 %32 Asus K50IJ Fan Replacement: passo 3, imagem 2 %32 Asus K50IJ Fan Replacement: passo 3, imagem 3 %32
    • Press the tabs on the battery and lift them. The battery should come out easily.
    Pergunte ao FixBot
    Comentar
  4. Asus K50IJ Fan Replacement, Fan: passo 4, imagem 1 %32 Asus K50IJ Fan Replacement, Fan: passo 4, imagem 2 %32 Asus K50IJ Fan Replacement, Fan: passo 4, imagem 3 %32
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
    Pergunte ao FixBot
    Comentar
  5. Asus K50IJ Fan Replacement: passo 5, imagem 1 %32
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
    Pergunte ao FixBot
    Comentar
  6. Asus K50IJ Fan Replacement: passo 6, imagem 1 %32 Asus K50IJ Fan Replacement: passo 6, imagem 2 %32
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
    Pergunte ao FixBot
    Comentar
  7. Asus K50IJ Fan Replacement: passo 7, imagem 1 %32
    • Unplug the wire cable attached to the fan by pulling it out .
    Pergunte ao FixBot
    Comentar
  8. Asus K50IJ Fan Replacement: passo 8, imagem 1 %32 Asus K50IJ Fan Replacement: passo 8, imagem 2 %32
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 1,192
