Ir para o conteúdo principal
Asus G75VW-BHI7N07 USB Port Replacement
O que você precisa
  1. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: passo 1, imagem 1 %32 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: passo 1, imagem 2 %32 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: passo 1, imagem 3 %32
    • Remove the screws around the back cover using a Phillips #1 screwdriver.
    • Take the back cover off using the opening tool.
  2. Asus G75VW-BHI7N07 USB Port Replacement: passo 2, imagem 1 %32 Asus G75VW-BHI7N07 USB Port Replacement: passo 2, imagem 2 %32 Asus G75VW-BHI7N07 USB Port Replacement: passo 2, imagem 3 %32
    • Once you get rid of the back cover, spot all the screws marked ‘A’. There should be 10 in total.
    • Remove the battery using the slide release button.
    • This should expose 2 more ‘A’ marked screws.
    • Remove those using the same screwdriver.
  3. Asus G75VW-BHI7N07 USB Port Replacement: passo 3, imagem 1 %32 Asus G75VW-BHI7N07 USB Port Replacement: passo 3, imagem 2 %32
    • Using the opening tool, remove the disc drive cover.
    • Spot the 6 ‘B’ marked screws and remove them using the Phillips #1 screwdriver.
  4. Asus G75VW-BHI7N07 USB Port Replacement: passo 4, imagem 1 %32 Asus G75VW-BHI7N07 USB Port Replacement: passo 4, imagem 2 %32
    • Using the opening tool, pry open the keypad platform.
    • You will need to use your hands to get to the laptop’s internal systems by lifting the keypad platform.
  5. Asus G75VW-BHI7N07 USB Port Replacement: passo 5, imagem 1 %32 Asus G75VW-BHI7N07 USB Port Replacement: passo 5, imagem 2 %32 Asus G75VW-BHI7N07 USB Port Replacement: passo 5, imagem 3 %32
    • Now that the fans are exposed, use the opening tool to unhook them at the 4 connecting points.
    • Detach the blue-colored electrical component using the opening tool.
    • Detach the white and black colored electrical component using the opening tool.
  6. Asus G75VW-BHI7N07 USB Port Replacement: passo 6, imagem 1 %32
    • Using the Phillips #0 Screwdriver, remove the 5 screws around the edges of the motherboard.
    • Remove the 2 screws around the fan using the Phillips #0 Screwdriver which should be near the motherboard.
  7. Asus G75VW-BHI7N07 USB Port Replacement: passo 7, imagem 1 %32
    • Carefully lift the motherboard up using the opening tool.
    • You should be able to see the USB port.
    • Now you will be able to desolder the faulty USB port.
    • Here is a link on desoldering Como soldar e dessoldar contatos
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 604
