Ir para o conteúdo principal
Asus F6A-X2 RAM Replacement
O que você precisa
  1. Asus F6A-X2 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Asus F6A-X2 RAM Replacement, Back Access Panel: passo 2, imagem 1 %32 Asus F6A-X2 RAM Replacement, Back Access Panel: passo 2, imagem 2 %32
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
    Pergunte ao FixBot
    Comentar
  3. Asus F6A-X2 RAM Replacement: passo 3, imagem 1 %32 Asus F6A-X2 RAM Replacement: passo 3, imagem 2 %32 Asus F6A-X2 RAM Replacement: passo 3, imagem 3 %32
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
    Pergunte ao FixBot
    Comentar
  4. Asus F6A-X2 RAM Replacement, RAM: passo 4, imagem 1 %32 Asus F6A-X2 RAM Replacement, RAM: passo 4, imagem 2 %32
    • Make sure to check the RAM specifications on the device page.
    • There are two white plastic tabs holding the RAM in place. Place two fingers on each of these tabs, and pull outward.
    • You will hear a pop and visibly see the RAM move upwards.
    • Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
    Pergunte ao FixBot
    Comentar
  5. Asus F6A-X2 RAM Replacement: passo 5, imagem 1 %32 Asus F6A-X2 RAM Replacement: passo 5, imagem 2 %32
    • Repeat the process from the previous step to remove the bottom RAM.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jonathan
Membro desde: 04/24/14
1.174 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 10-56, Amido Spring 2014 Membro de Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Membros
Autoria de 12 guias
1Comentário do guia
Tutorel simple et très clair.
Merci
alainbadinier - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 919
