Ir para o conteúdo principal
Asus F6A-X2 Battery Replacement
  1. Asus F6A-X2 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jonathan
Membro desde: 04/24/14
1.174 Reputação
Autoria de 11 guias
Equipe
Cal Poly, Team 10-56, Amido Spring 2014 Membro de Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 22
Ao todo: 1,067
