Ir para o conteúdo principal
Asus Eee PC 900 SSD Replacement
O que você precisa
  1. Asus Eee PC 900 SSD Replacement, Battery: passo 1, imagem 1 %32 Asus Eee PC 900 SSD Replacement, Battery: passo 1, imagem 2 %32 Asus Eee PC 900 SSD Replacement, Battery: passo 1, imagem 3 %32
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
    Pergunte ao FixBot
    Comentar
  2. Asus Eee PC 900 SSD Replacement: passo 2, imagem 1 %32
    • Slide the battery out while holding the left locking tab in the unlocked position.
    Pergunte ao FixBot
    Comentar
  3. Asus Eee PC 900 SSD Replacement, SSD: passo 3, imagem 1 %32 Asus Eee PC 900 SSD Replacement, SSD: passo 3, imagem 2 %32 Asus Eee PC 900 SSD Replacement, SSD: passo 3, imagem 3 %32
    • Remove the small sticker on the right side of the SSD/RAM compartment cover.
    • Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
    Pergunte ao FixBot
    Comentar
  4. Asus Eee PC 900 SSD Replacement: passo 4, imagem 1 %32 Asus Eee PC 900 SSD Replacement: passo 4, imagem 2 %32
    • Using a plastic opening tool, lift up the bottom of the SSD/RAM compartment cover.
    • Lift the cover away from the laptop.
    Pergunte ao FixBot
    Comentar
  5. Asus Eee PC 900 SSD Replacement: passo 5, imagem 1 %32 Asus Eee PC 900 SSD Replacement: passo 5, imagem 2 %32 Asus Eee PC 900 SSD Replacement: passo 5, imagem 3 %32
    • Remove the two 4.76 mm Phillips #0 screws that secure the SSD.
    • When the screws are removed, one end of the SSD should pop up.
    • Slide the SSD out of its socket and lift it out of the compartment.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Brian Carreon
Membro desde: 01/25/12
300 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-27, Amido Winter 2012 Membro de Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Membros
Autoria de 16 guias
5Comentários do guia
What for specifications do the SSD has? I want to replace, too but do not know the execactly specs. I bought a 30GB m-sata ssd and this is not accepted by bios and does not work.
Marcus - Responder Compartilhar
Refering from this site: http://www.minipciessd.com/
It seems you'll need a miniPCIe SSD and not a m-sata (even if the form factor seems the same) and that's why your bios doesn't recognize it.
adrien - Responder Compartilhar
There are now miniPCIe mSATA adapters. I plan to try this.
ejolson - Responder Compartilhar
Same problem here. I ended up putting my “new!” 64GB SSD in an adaptor and used it for a few years until it wore out!
Evidently the chips aren’t much good as withstood less than 700GB of writes according to the onboard diagnostics.
Strangely enough the adaptor worked with the original 16GB SSD and the 64.
Andre De Guerin - Responder Compartilhar
what kind of adapter you use? My ssd died….
rui fontes - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 88
Ao todo: 46,632
