Ir para o conteúdo principal
Asus Eee PC 1201N Display Replacement
O que você precisa
  1. Asus Eee PC 1201N Display Replacement, Battery: passo 1, imagem 1 %32
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
    Pergunte ao FixBot
    Comentar
  2. Asus Eee PC 1201N Display Replacement: passo 2, imagem 1 %32
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
    Pergunte ao FixBot
    Comentar
  3. Asus Eee PC 1201N Display Replacement: passo 3, imagem 1 %32
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
    Pergunte ao FixBot
    Comentar
  4. Asus Eee PC 1201N Display Replacement, Display: passo 4, imagem 1 %32 Asus Eee PC 1201N Display Replacement, Display: passo 4, imagem 2 %32
    • Remove the six screw on the front cover by using the plastic opening tool. Then, remove the six 4.6mm screws using the J0 Phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Asus Eee PC 1201N Display Replacement: passo 5, imagem 1 %32
    • Using the plastic opening tool, separate the over from the netbook.
    Pergunte ao FixBot
    Comentar
  6. Asus Eee PC 1201N Display Replacement: passo 6, imagem 1 %32
    • You must separate the hinge cover from the cover before removing the cover.
    Pergunte ao FixBot
    Comentar
  7. Asus Eee PC 1201N Display Replacement: passo 7, imagem 1 %32
    • After removing the cover, remove the two 4.6mm screws using the J0 Phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Asus Eee PC 1201N Display Replacement: passo 8, imagem 1 %32
    • There are two screws on the left and right side of the display. Remove all four 3mm screws using the J0 Phillips head to separate the LCD from the display cover.
    • The left side will have a magnet covering the bottom screw remove the magnet. Be sure to replace when reassembling.
    Pergunte ao FixBot
    Comentar
  9. Asus Eee PC 1201N Display Replacement: passo 9, imagem 1 %32
    • Pull up on the video cable on the back of the LCD display to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team 2-3, Nance Fall 2016 Membro de USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 935
