Ir para o conteúdo principal
Asus Eee PC 1005PEB Battery Replacement
  1. Asus Eee PC 1005PEB Battery Replacement, Battery: passo 1, imagem 1 %32
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Asus Eee PC 1005PEB Battery Replacement: passo 2, imagem 1 %32
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
    Pergunte ao FixBot
    Comentar
  3. Asus Eee PC 1005PEB Battery Replacement: passo 3, imagem 1 %32 Asus Eee PC 1005PEB Battery Replacement: passo 3, imagem 2 %32
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
    Pergunte ao FixBot
    Comentar
  4. Asus Eee PC 1005PEB Battery Replacement: passo 4, imagem 1 %32
    • Using both hands, pull the battery horizontally away from the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
Aaron Arenas
Membro desde: 04/20/14
751 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-32, Maness Spring 2014 Membro de Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 24
Ao todo: 2,030
