Ir para o conteúdo principal
Asus Chromebook C300SA-DS02 Display Assembly Replacement
O que você precisa
  1. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Keyboard: passo 1, imagem 1 %32 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Keyboard: passo 1, imagem 2 %32
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 2, imagem 1 %32 Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 2, imagem 2 %32 Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 2, imagem 3 %32
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 3, imagem 1 %32 Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 3, imagem 2 %32 Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 3, imagem 3 %32
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 4, imagem 1 %32
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Battery: passo 5, imagem 1 %32 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Battery: passo 5, imagem 2 %32
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 6, imagem 1 %32 Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 6, imagem 2 %32
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 7, imagem 1 %32
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Display Assembly: passo 8, imagem 1 %32 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Display Assembly: passo 8, imagem 2 %32
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 9, imagem 1 %32
    • Peel back the tape covering the display cable.
    • Ease the cable towards the screen and out from the connector.
  10. Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 10, imagem 1 %32
    • Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
  11. Asus Chromebook C300SA-DS02 Display Assembly Replacement: passo 11, imagem 1 %32
    • Gently lift the display assembly up and away from the laptop.
Conclusão
Celina Monteiro
Membro desde: 10/17/17
224 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 181
