Ir para o conteúdo principal
Asus Chromebook C300SA-DS02 LED Screen Replacement
O que você precisa
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: passo 1, imagem 1 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: passo 1, imagem 2 %32
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 2, imagem 1 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 2, imagem 2 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 2, imagem 3 %32
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 3, imagem 1 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 3, imagem 2 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 3, imagem 3 %32
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 4, imagem 1 %32
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: passo 5, imagem 1 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: passo 5, imagem 2 %32
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 6, imagem 1 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 6, imagem 2 %32
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 7, imagem 1 %32
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: passo 8, imagem 1 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: passo 8, imagem 2 %32
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 9, imagem 1 %32
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 10, imagem 1 %32
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 11, imagem 1 %32
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 12, imagem 1 %32
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 13, imagem 1 %32
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 14, imagem 1 %32 Asus Chromebook C300SA-DS02 LED Screen Replacement: passo 14, imagem 2 %32
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
Conclusão
Uma outra pessoa concluiu este guia.
Celina Monteiro
Membro desde: 10/17/17
224 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
Membros da 3
Autoria de 9 guias
Um comentário
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 688
