Ir para o conteúdo principal
Asus Chromebook C101P Keyboard Replacement
O que você precisa
  1. Asus Chromebook C101P Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
    Pergunte ao FixBot
    Comentar
  2. Asus Chromebook C101P Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
    Pergunte ao FixBot
    Comentar
  3. Asus Chromebook C101P Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the four black screws where the rubber grips were.
    Pergunte ao FixBot
    Comentar
  4. Asus Chromebook C101P Keyboard Replacement: passo 4, imagem 1 %32 Asus Chromebook C101P Keyboard Replacement: passo 4, imagem 2 %32
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
    Pergunte ao FixBot
    Comentar
  5. Asus Chromebook C101P Keyboard Replacement: passo 5, imagem 1 %32 Asus Chromebook C101P Keyboard Replacement: passo 5, imagem 2 %32 Asus Chromebook C101P Keyboard Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Bryan Acosta
Membro desde: 10/25/19
401 Reputação
Autoria de 3 guias
Equipe
2Comentários do guia
This did not work my laptop won't turn on now. Any suggestions?
Destiny Wright - Responder Compartilhar
We’re sorry to hear that. We recommend you contact iFixit directly for support on this issue or to contact ASUS for further help.
Bryan Acosta - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 44
Ao todo: 2,171
