Ir para o conteúdo principal
Asus A53U-ES21 Keyboard Replacement
O que você precisa
  1. Asus A53U-ES21 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Asus A53U-ES21 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
    Pergunte ao FixBot
    Comentar
  2. Asus A53U-ES21 Keyboard Replacement: passo 2, imagem 1 %32 Asus A53U-ES21 Keyboard Replacement: passo 2, imagem 2 %32
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
    Pergunte ao FixBot
    Comentar
  3. Asus A53U-ES21 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Asus A53U-ES21 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Asus A53U-ES21 Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Asus A53U-ES21 Keyboard Replacement: passo 4, imagem 1 %32 Asus A53U-ES21 Keyboard Replacement: passo 4, imagem 2 %32 Asus A53U-ES21 Keyboard Replacement: passo 4, imagem 3 %32
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
    Pergunte ao FixBot
    Comentar
  5. Asus A53U-ES21 Keyboard Replacement: passo 5, imagem 1 %32 Asus A53U-ES21 Keyboard Replacement: passo 5, imagem 2 %32 Asus A53U-ES21 Keyboard Replacement: passo 5, imagem 3 %32
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
    Pergunte ao FixBot
    Comentar
Conclusão
Mabel Trager
Membro desde: 10/23/18
180 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 920
