Ir para o conteúdo principal
Asus A52F Cooling System Replacement
O que você precisa
  1. Asus A52F Cooling System Replacement, Battery: passo 1, imagem 1 %32 Asus A52F Cooling System Replacement, Battery: passo 1, imagem 2 %32
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
    Pergunte ao FixBot
    Comentar
  2. Asus A52F Cooling System Replacement: passo 2, imagem 1 %32 Asus A52F Cooling System Replacement: passo 2, imagem 2 %32
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
    Pergunte ao FixBot
    Comentar
  3. Asus A52F Cooling System Replacement, Lower Case: passo 3, imagem 1 %32 Asus A52F Cooling System Replacement, Lower Case: passo 3, imagem 2 %32 Asus A52F Cooling System Replacement, Lower Case: passo 3, imagem 3 %32
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
    Pergunte ao FixBot
    Comentar
  4. Asus A52F Cooling System Replacement: passo 4, imagem 1 %32 Asus A52F Cooling System Replacement: passo 4, imagem 2 %32
    • Slide the back panel away and remove the panel.
    Pergunte ao FixBot
    Comentar
  5. Asus A52F Cooling System Replacement, Cooling System: passo 5, imagem 1 %32 Asus A52F Cooling System Replacement, Cooling System: passo 5, imagem 2 %32
    • Removal of cooling system will void your warranty. Proceed with caution.
    Pergunte ao FixBot
    Comentar
  6. Asus A52F Cooling System Replacement: passo 6, imagem 1 %32 Asus A52F Cooling System Replacement: passo 6, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove all six screws from the cooling system.
    • Unplug the fan power connector.
    Pergunte ao FixBot
    Comentar
  7. Asus A52F Cooling System Replacement: passo 7, imagem 1 %32 Asus A52F Cooling System Replacement: passo 7, imagem 2 %32
    • Carefully grab the copper pipe and start to lift upward.
    • Lift to the angle shown and then start to slide it out.
    Pergunte ao FixBot
    Comentar
  8. Asus A52F Cooling System Replacement: passo 8, imagem 1 %32
    • Clean the designated area with isopropyl alcohol on a microfiber cloth
    • Replace with new thermal paste if needed
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Bradley Varnum
Membro desde: 03/09/17
345 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 1,292
