Ir para o conteúdo principal
Asus 1015E-DS03 Trackpad Replacement
O que você precisa
  1. Asus 1015E-DS03 Trackpad Replacement, Battery: passo 1, imagem 1 %32
    • Hold the laptop using both hands with the battery facing upwards.
    Pergunte ao FixBot
    Comentar
  2. Asus 1015E-DS03 Trackpad Replacement: passo 2, imagem 1 %32
    • Push the two tabs located below the battery in towards each other using your thumbs.
    Pergunte ao FixBot
    Comentar
  3. Asus 1015E-DS03 Trackpad Replacement: passo 3, imagem 1 %32
    • Push the battery upwards and out of the laptop as shown.
    Pergunte ao FixBot
    Comentar
  4. Asus 1015E-DS03 Trackpad Replacement: passo 4, imagem 1 %32
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    Pergunte ao FixBot
    Comentar
  5. Asus 1015E-DS03 Trackpad Replacement, Keyboard: passo 5, imagem 1 %32
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
    Pergunte ao FixBot
    Comentar
  6. Asus 1015E-DS03 Trackpad Replacement: passo 6, imagem 1 %32 Asus 1015E-DS03 Trackpad Replacement: passo 6, imagem 2 %32
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
    Pergunte ao FixBot
    Comentar
  7. Asus 1015E-DS03 Trackpad Replacement: passo 7, imagem 1 %32
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. Asus 1015E-DS03 Trackpad Replacement: passo 8, imagem 1 %32
    • Using the spudger push the white clips upwards that are holding the cable.
    Pergunte ao FixBot
    Comentar
  9. Asus 1015E-DS03 Trackpad Replacement: passo 9, imagem 1 %32 Asus 1015E-DS03 Trackpad Replacement: passo 9, imagem 2 %32
    • Gently pull the strip out of the square slot.
    Pergunte ao FixBot
    Comentar
  10. Asus 1015E-DS03 Trackpad Replacement, Trackpad: passo 10, imagem 1 %32
    • Unscrew all of the indicated 5mm screws (11) using a #0 Philips head screwdriver.
    • One of the screws will be covered by a sticker indicating that proceeding will void the warranty.
    Pergunte ao FixBot
    Comentar
  11. Asus 1015E-DS03 Trackpad Replacement: passo 11, imagem 1 %32 Asus 1015E-DS03 Trackpad Replacement: passo 11, imagem 2 %32
    • Before the baseboard can be fully removed from the laptop, you need to detach the small blue tab attached to the motherboard.
    • Gently lift up on the black plastic tab that is securing the blue tab in place.
    • Carefully pull the blue tab out of the dock.
    Pergunte ao FixBot
    Comentar
  12. Asus 1015E-DS03 Trackpad Replacement: passo 12, imagem 1 %32 Asus 1015E-DS03 Trackpad Replacement: passo 12, imagem 2 %32
    • Use the spudger from the laptop to 'pop' open the track-pad base, starting from the corner shown
    • Once the corner is popped it may be easier to use your fingers to pop off the entire track-pad base
    • You will hear popping. Although this is normal, use caution pulling the track-pad base from the rest of the laptop
    Pergunte ao FixBot
    Comentar
  13. Asus 1015E-DS03 Trackpad Replacement: passo 13, imagem 1 %32 Asus 1015E-DS03 Trackpad Replacement: passo 13, imagem 2 %32 Asus 1015E-DS03 Trackpad Replacement: passo 13, imagem 3 %32
    • Once the trackpad base is detached, flip it face-down.
    • Lift the small black tab that the blue flat cable is attached to.
    Pergunte ao FixBot
    Comentar
  14. Asus 1015E-DS03 Trackpad Replacement: passo 14, imagem 1 %32
    • Remove the 3mm screws (3) circled in red with a #0 Phillips head screwdriver.
    • The metal plate shown in blue will fall off by itself, replace it before re-securing the baseplate.
    Pergunte ao FixBot
    Comentar
  15. Asus 1015E-DS03 Trackpad Replacement: passo 15, imagem 1 %32 Asus 1015E-DS03 Trackpad Replacement: passo 15, imagem 2 %32 Asus 1015E-DS03 Trackpad Replacement: passo 15, imagem 3 %32
    • Detach the tape connecting the trackpad to the trackpad base, and carefully remove the trackpad.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Liam Monteith
Membro desde: 03/21/16
149 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 7-4, Benson Spring 2016 Membro de Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 50
Ao todo: 918
